Departure time not warming up the car
rishi.m3
Mustang Mach E
I have a departure time set up for several weekday mornings, but each time I come into the car, it's pretty cold. I have set the cabin temperature to "Warm" in departure settings. I usually don't charge overnight, and I have the "Allow start when vehicle is unplugged" set to on. Am I missing something? I have tried deleting and re-adding it too.
Mine has stopped preconditioning completely since 4.1.2.
Is yours preconditioning at all?
Flint302
Northern NJ
2021 Mach E Premium AWD, 2016 Audi A3
Retired government
I noticed when I set a departure time on Ford Pass it will sometimes miss. I have much better luck making the change while in the car. Also, whenever you get an "over the air" update--it usually erases everything--including max percentage charge.
Zassi
Jussi
Finland
Mach-E RWD SR
Yup, the unwritten rule that departure times don’t work without charging(atleast for me they haven’t in the past 16months)
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
I think you need to be plugged in to your L2 charger to precondition?
Bug, it works on my car. Double check the settings in the vehicle UI, they don't always get pulled down from the cloud properly.
Unplugged departure times will heat the cabin only, not the battery. I suggest plugging in if you have one available.
