Disable front camera washer?
Astraea
MMe Premium AWD ER
Not 100% sure if this is the right category for this so if it needs to be moved I apologize in advance. Anyway! Anyone know of a way to disable the front camera washer? We have lots of bugs up here and after the recent beautifying my baby got, I don't want to risk the washer fluid staying on with this heat on the front and messing with the coating. Plus I hate it that it sprays all over the front anytime I need to give the windshield a quick once over to clear debris to make sure the glass doesn't get marked up doing it dry. I personally think it's the dumbest thing to have a front washer and not a rear one and for it to pop out and spray sideways and not down off all things. Anyway, any help is appreciated! Thanks!! ?
Um, why would it be "staying on"? The pump only runs when you pull the stalk.
Pop out the frunk and disconnect/plug the hose going to the camera washer then.
Astraea
Astraea
MMe Premium AWD ER
I suppose I should clarify that I don't want the washer fluid to dry on the car and create a film on top of the coating. Do you know how to remove the hose without it making a mess? I'm assuming there is a pump that runs to it.
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Disconnect the hose and plug it. Problem solved.
zhackwyatt
I really don't think washer fluid is going to harm the paint any. If you ceramic coated it, then even less so. That's the purpose of it.
Chuck
Chuck
SoCal
Mustang Mach E 2021
I'm so glad I don't have to deal with flying insects. My car is 4 months old and I haven't tried the washers yet. I guess I should just to see if they work.
