Does the Mach-E Fly??
Jrny127
James
Portland, Or.
2022 Ford Mach-E Premium
Forklift Driver
Recently I noticed that my dash shows me “Ground Speed.” That made me wonder if my car flies and it changes to “Air Speed!”
lol just wondering why it had to tell me it’s ground speed!!!
Ford Mustang Mach-E Does the Mach-E Fly?? IMG_3322
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
It’s a Mustang thing. They all say that. Not sure when it started.
Jrny127
Jrny127
James
Portland, Or.
Forklift Driver
Well. Mustangs are horses. Horses don’t fly unless they are Pegasus! So, are Mustang’s becoming Pegasus’s??
Cars, trucks, motorcycles, bicycles, unicycles, skateboards, et. al, all have ground speed too.
Yep - it's just more information than you need while absolutely correct, and as mentioned is paying homage to the actual impetus for the name: the P-51 mustang (arguably the best piston engine fighter ever made when paired with the Merlin engine).
It's similar to the phrase "at a high rate of speed": speed is already defined to be a rate (distance over time) so the word "rate" is redundant - yet commonly used.
KlueBat
2022 Mach E AWD Premium, 2021 Mustang GT
The only way to know for sure would be to hand one over to Bo and Luke. They were more Dodge fans though, so not sure they would allow themselves to be caught in a Ford.
I still find it funny that Ford has identified one of its flagship products with an aircraft from an eventual GM division. The Merlin wasn’t included in the early versions because of politics and licensing. Licensing talks were under way between Packard (a division of GM) and Rolls-Royce long before the first RAF skunkworks conversion happened. ??
Yeah the naming history is pretty interesting.
Clearly the primary source of the name was the horse. You can tell from the horses everywhere on the car. That and the other animal named cars from Ford. Also the “pony” references.
The “ground speed” on some Mustangs is more of a tip of the hat to the plane.
IIRC it first appeared in the Mach 1 in the late 60s then returned in the 2013 redesign.
MellowJohnny
Christian
YYZ
Solution Architect
And let's not forget that wonderful Merlin engine can also end up in a car...
