Eibach Vehicle Selection (Missing?)
J-2023Premium
J
Winnipeg-MB Canada
2023 Mach-E Premium Glacier Grey
I want to purchase a lift kit for my 2023 MME Premium AWD | Standard Range
am I crazy?
Or it’s just not an option on the Eibach website?
Ford Mustang Mach-E Eibach Vehicle Selection (Missing?) IMG_3229
J-2023Premium
J-2023Premium
J
Winnipeg-MB Canada
Oops here is the correct YEAR
Same issue
Can’t see the AWD SR
Does that mean it doesn’t have a lift kit?
Thanks
Ford Mustang Mach-E Eibach Vehicle Selection (Missing?) IMG_3230
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
It doesn’t matter. They all have the same part number.
Ford Mustang Mach-E Eibach Vehicle Selection (Missing?) IMG_0469
Ford Mustang Mach-E Eibach Vehicle Selection (Missing?) IMG_0468
Ford Mustang Mach-E Eibach Vehicle Selection (Missing?) IMG_0467
AliRafiee
Ali
Seattle WA
Software Eng.
Wait. You said lift. Send them an email.
J-2023Premium
J-2023Premium
J
Winnipeg-MB Canada
Yeah lift, I did, no reply, this forum was my next hope lol
thank you!
Jeff-NoVA
Northern VA
2022 Mustang Mach-E Premium
Just call them. They answer.
MacherAWD
North Shore MA
Healthcare Software
Did you ever end up lifting your Mach-e? I just saw this online, wondering the pros/cons of this vs the eibach springs?
Also did you do yours yourself or have a shop do the work?
https://risingtuning.com/lift-kits/...ridGDB1ZRDOocwPfPLSZDO6OrFq94-HygTu6puu0jbBIZ
I will give my two cents... The advantage of the spacers over lift springs is they are cheaper, about $100-$150 less than a full set of springs and easier to install. They will lift the car between 1.5"-2" and you will retain the same quality of ride you have now. Going with lift springs, you have two options. Eibach lift springs or Ford OEM Rally springs. The Eibach lift springs will raise the car 1.5" and are about the same spring rate as your OEM's so the ride should be similar. The Ford Rally springs will raise the car between 3/4"-1" and have a lower spring rate giving you a smoother ride if that is something you are looking for. I've installed the Ford Rally springs on quite a few Mach-E's because the owners wanted a smoother ride.
MacherAWD
North Shore MA
Healthcare Software
Thank you, I am considering both approaches, based on what you say it would be between spacers and rally springs (my kids would appreciate a smoother ride). I have minimal experience in this kind of work, my good friend has more.
My thought is if he is comfortable doing either, Rally springs, if he can only handle spacers I would go that route. Just looking for more clearance as we are up in Maine a lot, and a few driveways I scrape every time I enter.
