Broke down Mach e
- Jeff
- Jun 6, 2021
- Pontiac , IL 61764
- 21 Ford Mustang Mach e, Premium AWD,extended range
- Transportation industry
We purchased a 2021 Ford Mustang Mach e premium extended range model with 20 miles on the odometer. On our way home from dealership while traveling 65 mph with 55 miles on the odometer the vehicle started flashing the following codes listed below on the dash screen.
1) Service vehicle soon
2) Pre collision assist not available
3) AWD fault Service required
4) 1 Pedal Drive fault, Press brake pedal to reduce speed
5) Stop safely now
6) Service Advance Trac
7) Full accessory power active
The car now has 1500 miles and this same thing has happened 5 more times. It seems like this happens more frequently at slower speeds with 1 pedal drive active when you are releasing your foot from accelerator pedal and preparing to stop. When this happens at slower speeds while preparing to stop at a stop sign the vehicle makes some very strange sounds like electrical motors clashing and the vehicle jerks back and forth very quickly several times. This has also happened at higher speeds with auto pilot active. I have noticed the weird sounds out the vehicle jerking back and forth when at higher speeds, 60 mph +. Only at slower speeds when preparing to stop.
When this happens the following messages appear on the ford pass app.
The vehicle has been back into the Ford service shop twice and is currently at the Ford dealership now.
Ford has not been able to figure out what is causing this to happen. Please let me know your thoughts and or recommendations. Any help would be appreciated.
5) Stop safely now
