Fast Charging at non-EA stations
@kWhpony
Bob
Star White Premium RWD ER
Retired technology professional
While much discussion has been held about the charging curve at EA stations, I don't recall anything about the experience at ChargePoint and others.
To be specific.....my road trip from suburban Chicago to Phoenix will take me through Oklahoma where Francis Energy has many stations delivering 150 & 350kw.
Will we experience the same charging curve at non-EA stations where we see it ramp down from peaks of up to 160, drop to 120, then 100, then 80, before falling to 11-12 when reaching 80% SOC?
mr_raider
Montreal, QC
Yes. People in Canada have tested the car on Petro Canada or Electric Circuit. This is simply a protection mechanism hard coded in by Ford. The charge rate is controlled by the vehicle software.
Charging curves on these other stations can be comparable depending on the capacity of the charger and how it is programmed. Best results will probably be at 350kW stations.I have a couple of non-EA charging sessions in https://www.macheforum.com/site/threads/my-travels-with-marlin-gb-fe-delivered.3298/
In particular, the Chargepoint in Kingsland GA only delivered half its advertised rate. Remember that you may need to have a separate app or RFID card for some other networks if they aren't part of FordPass.
balthisar
SE Michigan
2022 Expedition; 2025 Mach E Rally
Engineer@FoMoCo
And I suddenly realized that the border will someday re-open, and I have no idea whether my car will charge in Ontario. A quick check in the app is encouraging, though: in addition to giving me a 150 kW charger just east of London, it also properly routes me via the 402 by default instead of trying to force me through Windsor.
And, holy cow am I envious. There are more chargers in Oakville and Mississauga than there are Starbucks and Tims combined! On the other hand, I'd have to limp into Stratford if I were running low on juice in St. Marys.
MattG
Matt
Colorado
Mach-E, Crosstrek, Lotus Elise, Jeep Wrangler LJ
The fastest chargers I’ve used so far are Chargepoint 62.5kW stations; charging is pretty steady at a bit under 60kW until 80% when it hits the cliff. The first time I used one though the power varied wildly...it fluctuated between 35-45kW before hitting the 80% cliff. I wonder if the car was going through a learning process.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
I tried to use the EVgo a few times in Chicago but never any luck
Nope.
