Flat tire indicator reset
Mustangor
France
Mustang Mach-E 2024 SR RWD
I had a flat tire a few days ago. This puncture was signaled by an alert on the instrument panel. After repair, the tire pressure is now constant, but the tire is still indicated with the orange color, signaling a defect. Do I need to go to the dealership to "reset" the indicator ?
chillyWilly
William
2024 Mustang Mach E
Does it have an “OK” in the orange block somewhere? You just need to click the button on the right side of steering wheel to acknowledge it and then it goes away. At least that’s what mine did.
Mustangor
France
Yes, the block corresponding to the tire is orange. If I click on "OK" the alert goes away, but it comes again and again when I start the car. I found no way to remove it completly, and I suspect I'll have to go to the dealer...
Yes, replace the TPMS sensor. It may longer be reporting. A low tire can cause the sensor battery to deplete.
