Ford Mobile Charger.
Mauser
Canada
'22 Mach-e GT-PE Space White
Hello all,
I have a question about the mobile charger that comes with the MME: Are you able to adjust the amperage draw of the unit? I'm asking, because currently, my house has only a 100A service. I've had several electricians in for quotes and they've all said the same thing: Because I'm only running a 100A service, I need an interlock installed if I wanted a full 60A line run to the garage, this installation costs upwards of $4000. To avoid the interlock for the time being (can be installed at a later date) I can have a 30A breaker installed for the time being. Can the mobile charger adjust to a 24A charge rate like some of the after-market chargers (Grizzle-E, ChargePoint, etc), or will it just go right to drawing the full 32A?
Thanks in advance,
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
I think you're confusing the Ford Mobile Charger that comes with the car and the Ford Connected Charge Station. The mobile charger that comes with the car will only pull 32 A and is not adjustable. The Connected Charge Station can pull up to 48 A and I believe is configurable.
Honestly, you really don't need a 60 A breaker and a hardwired charger. I'd get a configurable one and set the limit lower to avoid the cost of upgrades to your house for something you probably don't need.
Mauser
Mauser
Canada
Sorry - yes, I updated my note above to 32A for the mobile charger. But yes, I was looking at one of the configurable ones, I was just curious if the mobile charger was configurable in the same way.
It is not.
Mrn
Pima County
MMES
Aviation
Some people find the 120 volt use of the charger adequate for their needs. There is a family in my neighborhood who keeps their Tesla plugged into a 120 volt, 20 amp outlet whenever they are home and they've been doing that for several years.
