hawkeye3point1
NH
Interesting. Does it keep the battery warm even after it has completed the charge cycle? (I hope not!)
IDK, never leave it on plug after charge complete/overnight like most.
Neil4Real
I believe it will warm/cool the pack as needed, so long as it’s within your charge schedule, even when your set charge level is reached. It shouldn’t get it to optimal temperature, like it does for departure schedules.
awp0
Aaron
boston, ma
MME Premium AWD ER
Makes sense, I guess? I’d like to know how it handles “anytime” charge schedules. I don’t think it should continue to keep the battery warm indefinitely after the target charge is reached.
Where do we see what version our cars are on? Not seeing it under General/About Sync.
Y look in settings under software updates, your last update might still be showing there.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51
This is what mine shows and waiting for update to try BlueCruise. I got car on 12/10 so not sure how long to receive update.
Tap the car icon in the upper left corner of the sync screen. Then tap the settings tab. Then scroll down to software ui dates. Your current OTA may still be listed there. That info goes away after awhile.
Darkenmage
Manny
Mach E GT AWDe and Honda Insight
Semi Retired
I have my updates turned OFF for auto-updates. I have 3.5.4 pending and I don't plan to install it. I assume it will eventually go away in notifications? And if so, will my ME get notified for newer updates or would I need to apply ones I bypassed altogether?
3.6.2 could be paused for new triggers due to issues with SYNC and profiles. A master reset (clear all settings) may be requires afterwards to solve lingering issues.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Ford Mustang Mach-E Ford Power-Up OTA Update Software 3.6.2 IMG_2355
You need to go to a dealer to get this fixed.
^^^ Why won’t I get it OTA?
The OTA was sent to your car in October, but didn't install because the vehicle wasn't sold yet. It's since expired and the only way now is for the dealer to manually update it. Tell them to do TSB 22-2105.
