FordPass Showing CRAZY Numbers
hammerg26
Hank
North Georgia
2024 Mach e
According to FordPass, my last public charging (at work) took my % from 59% to 86%, adding 172 kWh and charging for 17 hours and 23 minutes.
WTF?
FordPass is not reliable for data. Often posted.
RockinVs
MN
2023 Mach-E GT (Ghost)
Mine has been worse lately as well. Seems to be just adding charge times. I just worry about the percent charge.
RockinVs
MN
I only charge at home...
I've plugged it in recently and it would act like i never unplugged it, just adding to the previous time. I'm pretty sure the OP was not on the charger that long either.
hammerg26
hammerg26
Hank
North Georgia
2024 Mach e
Trying to establish a way to track charges, costs, cost per kWh, etc.
Not sure best way to get that data now.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Thankfully my JuiceBox software still works. More accurate there regardless since it tells how much was delivered vs how much absorbed.
When out and about, I rely on the public charger’s software/text messages.
JeffGo
Washington, USA
2024 MME GT in Eruption Green
Same here, 171 kWh on Sunday. Didn't get quite the range added that one would expect ... Actual was 46.7 (Emporia).
Also, the odometer reading was not correct, showed the odometer from 10 days before. owner.ford.com had the correct odometer reading.
And charge on Sept 28 was 20 kWh higher than the charger.
hammerg26
hammerg26
Hank
North Georgia
2024 Mach e
If I check the charger, I can get accurate data; now I just place the data in a spreadsheet for calculations…
Small daily routine…
