Forscan *working* mods?
btmache
Braden
Atlanta
2022 Mach E, Premium AWD, ER, 2018 Ford Expedition
The workaround is to set the mirrors to your desired tilt position and store it to button 3 (or any preset you don’t otherwise use). When you want to back up, just press 3.
That's not a bad way of achieving it, good suggestion. I'll just have to tell my son that button 3 is no longer his profile for the car :)
tomtel
Tomasz
Poland
Mustang Mach-e GT Performance, Ford EDGE ST
mechanic
Yes you have to have the the mirror adjustment button pressed (lit up) for whichever mirror you want to tilt. Then that mirror will tilt when you reverse. That's how all tilt-on-reverse mirrors I've ever used work. Has been working great on my MME since I set it up a while ago. I don't know why Ford doesn't enable this stuff from the factory.
what did you change to set this function?
I set what I needed and it doesn't work.
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
I followed this post. It is a little involved since you have to do the steps with the car after you’ve made the changes in Forscan.
If you’ve made the correct changes in Forscan and enabled the feature in Sync then perhaps you need to revisit the steps in the car and make sure you followed those correctly?
tomtel
Tomasz
Poland
mechanic
It works :) I didn't know about the process of learning the mirror to the rear position (Part C - Programming Reverse).
Now I did it and Everything works.
Thanks for your help ?
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Others I have personally done and can confirm work:
  • disable startup seatbelt reminder (the chimes that play unless you click seatbelt before
CHainster
I'm trying to help someone do this, but I can't find the link. I did it, but don't recall where I found it.
Might you remember?
tomtel
Tomasz
Poland
mechanic
Yes, change seatbelt policy settings to Europe
tomtel
Tomasz
Poland
mechanic
ABCDEFGH
1Feature NameModuleAddressValue ChangeEasy Method AvailableNotes
2Disable backup, driver & passenger seatbelt chimeIPC720-01-01xxxxxx0xxx--
jav_eee
Javi
Edinburg, TX
2025 Mach-E Select
Energy Industry
If these are your settings, could you post some photos or describe the enabled function, for example:
- Comfort Pet in APIM
- Echo Coach in APIM
- Sentinel in APIM
- Rear camera auto zoom in IPC
Thanks
did you ever find an answer to this?
SkywalkerSE
Sweden
2021 Mach-E Premium AWD
I disabled the double honk and activated backup tilt the other day. I toggled the backup tilt on and synced the correct position to my profile and everything worked just fine. However today it didn’t work and when I went to the settings I saw that the toggle was automatically switched off. I switched it on, tried it and everything worked as it did earlier. I stepped out of the car and suddenly heard that god-awful double honk.
Does anyone know why the backup tilt toggle resets itself and why the disabled double honk came back?
