Front Camera Fault Service Required
Socalsp3
CA
Ioniq 5, Mach E
I get this Front Camera Fault Service Required message on my dash every few days sometimes with Precollision assist failure message sometimes not. I took it to Robins Ford and they said they can't replicate it and they can't find the error code so they can't fix it. I showed them a picture of the messages. Should I be concerned? Is there anything I can do?
AZBill
My car has been in for the HVBJB recall and a camera fault. Talked to the dealer today the camera fault is due to the cable, the part is coming in today. It ended up with a message in FordPass to have it serviced. There is a CSP to replace the cable, my dealer said they have had many of these to repair.
The fault was initially intermittent for me, then it became permanent and I even lost adaptive cruise.
Socalsp3
CA
Ioniq 5, Mach E
I saw the TSB. But it looks like the issue needs to be permanent for them to replace it. The TSB requires a DTC code. Once the error goes away the DTC goes away is what I gather. Oh well at least there is a fix out there.
Ford Motor Company
Official Ford Account
Hi there! Will you please send us a message with your VIN and your local Ford dealer? We’d like to investigate this error message concern on our end. Thanks!
bergmi
Eau Claire, WI
2021 Ford Mach E Premium Extended Range
My car is in the shop right now for this issue (second visit). In my case, I was able to replicate the issue on the (interstate) highway with rough pavement seams/bumps. For this second visit, I had a video of the event, but it sure was frustrating to capture! Hopefully they can get me fixed up this time!
Flint302
Northern NJ
2021 Mach E Premium AWD, 2016 Audi A3
Retired government
I get that warning daily. In fact, if I don't get the warning I get scared.
Ford Motor Company
Good morning, Bill! I would be glad to help you out with these front camera concerns should you need further assistance. Just shoot us a direct message with your VIN and Ford dealer name/location, and I'll get right on it. To send a direct message, just click on our username and select "Send Direct Message". Thank you!
Comp247
Alex
Loomis, CA
MME E4x
My ‘21 suddenly started doing the same thing two weeks ago. Randomly comes on when the road is a little rough also does it sometimes on smooth road but when driving towards the sun. Then it will clear after 20-30 seconds. Just dropped it off for service to look at today. Did you guys have any luck getting it diagnosed?
Ford Motor Company
Hi there, Alex. This camera fault concern doesn’t sound like something we want you to experience with your Mach-E. Should you need further assistance, please send us a DM with your VIN and the name and location of your Ford dealer and I'd be happy to look into how I can assist you on my end. To send a direct message, just click on our username and select "Send Direct Message".
AZBill
After 4 weeks at the dealer for the camera fault and 4 recalls, I got the car back today and BlueCruise is working again, no pre-collision unavailable warnings. They had to replace the cable to the camera and the IPMA module. Glad I had an extended warranty, it covered it except for $100 deductible.
