Front Passenger Button & Lock
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
After 3 weeks, I finally got my issue taken care of. Took way longer than I thought it would, but it’s all good now, so happy about that
It's fixed!
The work order doesn't list the exact part numbers but based on some googling I think it's these:
Latch: LJ8Z-58219A65-H
Actuator assembly: LJ8Z-14A626-AB
Pretty sure they tried the latch first and then had to replace the "actuator assembly" - which actually just appears to be the whole external trim piece with the keyless entry panel and such - but it looks like it has some sensor/module attached to it that was likely the problem. I think the original error they saw said it wasn't communicating with the latch, which is why they tried that first. But I'm wondering if that was just a symptom of the actuator assembly failure and they maybe didn't need to replace the latch. Who knows.
Here's the detail from the work orders if you can make more of it than me:
You had two parts replaced, the door latch inside the door, and the exterior door button/moulding.
valfam
Ruben
JK and a WKII both gone :-( Now 23 MMEP Sta
network admin
I picked up the car. They said I need to go back after they order the parts. It looks like they are going to replace both things, the button and the other thing. They also said they are seeing charging errors on the battery, I told them I have not seen any charging errors, they later tell me I would not see the error. I thought that was strange. They are also ordering some part for the battery. I don't like the idea of them messing around with my battery, but I guess I have no choice.
That's good - Hopefully that's the case.
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
good luck. Hopefully it doesn’t cause any other issues
Just Lurking
Paul
Washington
2022 Mach-E GT
FrankieD
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
