Frozen Directions beside odometer?? Help
dolvio
Canada
2024 Select
2024 Mach-e. I use Google Maps often and the directions now show up on the screen behind the steering wheel. I guess this was in an update recently? What’s happening is those directions get frozen and don’t change for the duration of the trip? Any tips or insight into why and how to fix? Thank you.
Ford Mustang Mach-E Frozen Directions beside odometer?? Help IMG_8586
DugthePug Dad
Pat
2023 Mach E premium
I’m not an expert.
Try rebooting sync and if that doesn’t work then disconnect the 12v.
Again not an expert…
If that happens, enter a destination into the car's navigation system, then end navigation with the red X on the screen. That should clear it.
dan_meh
Daniel
Alexandria, VA
Technical Writer
I had this happen once with Apple Maps. I did the IT thing: turned it off and then turned it back on. Worked.
It hasn’t happened again so I just chalked it up to gremlins.
Klaxon
2022 Mach-E | Premium | AWD
Its been happening to me too since the last iOS update.
chuckles
2021 Job 1 RWD Mustang Mach E
I had this happen a year or two ago. I had to resort to shutting the car off, counting to ten, and restarting. Rebooting the central display with vol-down+next-track didn’t fix it.
