HELP - Multiple fault warnings after latest OTA
Teslaeata
Nottingham, England, UK
For information, my right rear door module threw DTCs and the dash warning apparently for no other reason than updates loaded at dealership during that HVBJB replacement.
There was no physical or other work undertaken in the area of the right rear door, or any doors.
Would’ve cost nearly £800 to replace but for warranty contribution.
Therefore, there need not be physical evidence of damage, connection or other issue causing the fault reporting.
Hope this is of some interest and/or helps in at least a small way.
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
I have an FDRS license good through tomorrow. Once I am done doing what I need to do with it, I will get you the files in case you need to program it. Hopefully it doesn't ban my account before I get a chance to grab them.
Edit: I got the files. If the module is not on the AM strategy when you put it in, you should update it to the current version that the one that is in your car now is on. If that's the case, lmk and I'll walk you through it. You would need FORScan.
Many thanks Javier 👍
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
The photo is the module from my car. Hopefully the module from the scrappy will be the same (I uploaded the photo to the scrappy website so the one they send should be the same, I so hope so 🤔 🤞🤞)
Module they were going to send me was the wrong one. They are sourcing the correct one but delivery might not be until late June 😬. Hey ho!
Out of interest what is the difference between all the different module types? There is :-
JX7T-14B531-BD, JX7T-14B531-BC - These are both marked driver and I think they are the same?
JX7T-14B533-BG, JX7T-14B533-BC - These are both marked Passenger, are they for the rear doors?Are there others?
rugedraw
Javier
Miami, FL
Auto Sales
Unfortunately, I don't have access to the parts catalog in PTS/OASIS anymore. Not sure what the difference is.
Michael MM
Michael MM
London, UK
Mach-E RWD XR
This is a copy-paste of the ChatGPT response after I get it your message. Here it goes:
Yes — Ford’s numbering convention here is actually pretty logical once you split the base number from the suffix.
The important part is:
  • 14B531 = Driver Door Module (DDM)
  • 14B533 = Passenger Door Module (PDM)
So:
Part numberMeaning
JX7T-14B531-BDDriver/front left door module
JX7T-14B531-BCDriver/front left door module
JX7T-14B533-BGPassenger/front right door module
JX7T-14B533-BCPassenger/front right door module
The 531 vs 533 distinction is the key thing. Ford consistently uses:
  • 531 = left/driver
  • 533 = right/passenger
The “Driver” and “Passenger” labels are therefore referring to the front doors, not rear doors. Rear doors usually have simpler slave modules or LIN-controlled motors depending on vehicle/platform.
The final two letters (BC, BD, BG, etc.) are revision/feature variants. They usually indicate:
  • hardware revision
  • firmware generation
  • option level
  • regional spec
  • mirror/power-fold/BLIS support
  • memory seat compatibility
  • safe-lock/alarm support
Ford often keeps the same base function but changes suffixes as features evolve. People retrofitting Ford modules run into this a lot. For example, some suffixes support BLIS or power-fold mirrors while lower trims do not.
So your assumption is mostly correct:
  • JX7T-14B531-BC and BD are both driver door modules and may interchange physically
  • JX7T-14B533-BC and BG are both passenger door modules and may interchange physically
…but whether they fully work depends on:
  • your exact vehicle/platform
  • feature set
  • As-Built configuration
  • firmware compatibility
Ford modules are often programmable via FORScan, but not always plug-and-play.
There absolutely are other variants. You’ll commonly see:
  • -AA
  • -AB
  • -AC
  • -AE
  • -AG
  • -AK
  • etc.
Those are usually earlier or alternate revisions for different trims/models/years. Examples of other JX7T door modules include:
  • JX7T-14B533-AE
  • JX7T-14B533-AG
  • JX7T-14B531-AK
One more useful detail:
Ford engineering numbers also encode the original vehicle program:
  • JX7T is the engineering prefix/platform generation
  • different prefixes (H1BT, DG9T, LU5T, etc.) are different eras/platforms but often similar module families
So when matching replacements, the safest approach is:
  1. Match the full part number exactly if possible
  2. If not, keep:
    • same 14B531 or 14B533
    • same platform family (JX7T)
  3. Then verify features/coding compatibility before swapping suffix revisions.
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
Hi Michael,
Wow, thanks so much for all that info, that is so useful. So as my driver door (front right) is a JX7T-14B531-BC (Driver/front left) the list is aimed at left hand drive cars, makes sense.
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
Hi Michael @Michael MM, sorry should have updated earlier. Received the correct module, fitted it and no difference. As Built coding was correct and module tested ok with FORScan. Connecting my Autel tool and pressing on the door to car harness seemed to generate another fault code. Not pressing the harness the fault code would clear, pressing again, fault code back again. So took the door off and inspected the wiring, hoping to find a broken wire but no luck there either.
So door back on, and original module back in and I’ll leave it for now to see if anyone on this wonderful forum has a fix solution 🤞. Sorry wish I had some positive news.
Michael MM
Michael MM
London, UK
Mach-E RWD XR
It is a pity all your efforts did not yield the desired results.
I am still in contact with Ford Customer Service. They are trying to convince the authorised service centre to swallow some of the quoted costs.
BOTH Ford and TrustFord have so far declined to provide detailed description of what is wrong. The have BOTH declined to quote the part numbers of the modules they claim need replacing. Quite interesting. So they want to take money for parts and labour, but they do not want to provide verifiable information that can be checked independently of neither the components, nor, consequently, of the time and labour it would take to replace those.
The more this drags on, the less confident I get that either of them actually knows what the issue is.
Not happy, I am.
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
Not happy, I am.
I completely empathise. It does seem a little strange, and as much as the last and the only one OTA I’ve had in a year (OBCC-AS.AU, the one you mentioned in your first post), my ‘door malfunction’ problem started. As much as the OTA was not related to the door module, my experience with programming, changes in coding can inadvertently affect other parts of the program. Who knows the next OTA (if I ever get one), may fix the problem 🤞🤞.
clayton
clayton
united Kingdom
Ford Mustang Mach E Awd First Edition
Hi, did you ever sort this? I’ve just had the same problem after the same update. Ford are trying to charge me £90 to read the faults when I don’t think it’s the car, I think it’s the update that’s caused the problem. Also would you know the best OBD reader in the UK?
Edge2MME
Lorenzo
Kent
Mach-E GT
I use Veepeak OBDCheck BLE Bluetooth OBD II Scanner which may be cheaper on ebay than AMZ with Car Scanner IOS app https://www.carscanner.info/ it works for andriod also, theres quite a few threads on here and some videos on ytube which may help
MikeC
Scotland ???????
Mach-e EXT AWD
Retired Engineer
Unfortunately not sorted yet and no further OTA’s. Try FORscan :-https://forscan.org/home.html
You’ll need to buy a suitable OBD2 adapter. The above website gives a list of supported adapters. Good luck, and if you do find a fix please let me know.
