Home Charging Schedule Issue
TRP
Mach E P4x, Ford F150
I had an issue getting a new phone set up as a key and in the process had to do a factory reset. PAAK is back on both phones........BUT..........I forgot it would erase my Home as a charging location and its schedule. So, I attempted to reset that. Home is set and it will only charge to 90% as I wanted but it doesn't allow me to set the time. It just charges to 90 whenever plugged in. No big deal for me really since I pay a flat rate 24/7 but it worked before the reset so I'd like to get it back.
Am I missing something?
Resetting up the phone has ZERO issue on the Home charging. It should have reappeared just fine.
To fix your specific problem, select Use Preferred Charge Settings, not Charge When Plugged In.
TRP
I'll check that this is where the issue lies.
Setting up PAAK did not cause the issue. Doing a Factory Reset in order to set up PAAK did.
TRP
RickMachE, if you would be so kind as to show me where I can select Preferred Charge Times VS Charge When Plugged In I would appreciate it. I don't seem to have that option
Ford Mustang Mach-E Home Charging Schedule Issue IMG_0594
Ford Mustang Mach-E Home Charging Schedule Issue IMG_0595
In the app.
Yes, a factory reset would do that. Unfortunately it was likely unnecessary.
TRP
Perhaps, I could not get any progress until afterwards tho. I own that
TRP
In the app.
OK, I just did that and it accepted in the app. Previously it would just create an error. I'll double check in the car later if it actually stuck this time.
Oldlawman
Essex UK
"Rosie" - Rapid Red Mach E AWD EXTD
I hope this is the correct thread to post this query in - apologies if not.
My electricity supplier's overnight cheap rate is between 00:00 - 07:00. I have solar panels and my Mach e to cater for during this period. I do not use my Mach every day and do quite low mileage so it only needs usually 15-20% top up at a session. I have programmed my Inverter to charge the Mach 00:00 to 03:00 and the solar storage batteries 03:00 to 07:00. On the Mach screen I have set the daily charge schedule time to 00:00 - 03:00. Do I need to make any allowance for departure time?
