- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Yeah 11.9V is a little low. I have a theory that it only checks the battery voltage every so often (once per hour?) so it might be a little late kicking in. Try discharging at something like 1-2A and see if the voltage threshold changes, that might answer that question.Ran another discharge test at 5A today (click on graph for larger version), and let it run for two charging cycles. Power off, MME at rest, load at 12V jump points (as you noted 12V gnd sensor in circuit), used OBD "power cord" for 12V measurement (5A is not flowing through any of the voltage sense path). Horizontal axis is hours.
Not sure if 11.9V is optimal for the low end voltage, however what is clear is that MME is reliably identifying the need to charge, then charging the LVB. Unclear why some are still have 12V LVB low voltage problems. I am running the latest MME (FDRS) software as of November. Turned off the 5A active load at the very end right side.
