E90alex
Seattle, WA
‘25 MME GT
It’s not so much the fact the cable is left plugged in, but the battery needs to be at rest for several hours so the voltages can stabilize and the BMS can gather resting cell voltage readings.
Just an update here, but it appears Ford has changed the BECM software this year, which makes it much harder to increase the state of health reading with calibration.
I did my semi-annual battery calibration, but I was only able to get an increase from 89.0% to 90.0% SoH after several deep calibration cycles. Last year I got a 5% increase (from 90 to 95%) for comparison.
This was a charge session from 3.5% SoC displayed to 100%:
Ford Mustang Mach-E HV Battery Calibration Procedure IMG_0695
Ford Mustang Mach-E HV Battery Calibration Procedure IMG_6800
The car took 90.9 kWh from the wall and put 85.5 kWh into the battery (94% efficient charging at 40A) to add 96.5% of charge.
85.5/.965 = 88.6 kWh usable capacity after 3 years and 33k miles. If we assume 91 kWh usable, my actual battery state of health is around 97%. But it's only reading at 90%. Therefore the SoH reading is no longer reliable in latest software, it's probably artificially low, especially if you charge often and shallow like I do.
Again I repeated the procedure several times (below 5% to 100%) with no improvement. I also checked my battery health in FDRS, I have about 1% capacity variation between the cells but otherwise no "weak" cells to cause that kind of discrepancy. It's just the software causing the low SoH readings, battery is fine.
Based on voltage readings, I'm getting 388V down to 322V from the pack (94S), which seems like pretty much the full range. I don't like to go below 320V resting because that's the edge of the voltage cliff at the end of the discharge curve. My goal is to arrive at the charger with about 330V left during road trips, which is happening around 10% displayed.
Interesting Lee. I’m in the process of going my 6 month calibration. I’ll likely hit 5%< on Sunday in my 2021. I’ll post how things workout when I’m done though I doubt I’ll magically end up with a correct reading from the obd2 reader.
Mache_Nor
Norway
MachE LR RWD
Seems I get similar results. Bear in mind that this is a reading below the recommended 25C temperature as well that it’s 30 min after car stopped charging, but by same measurements as you it would be around 94% SoH. Car has driven close to 128 000 km / 80 000 miles (21’ job 2).
Edit: reading done though Car Scanner Pro.
Edit 2: also added around 89 kWh energy from charger with around 8% battery
according to charger (before loses).
Ford Mustang Mach-E HV Battery Calibration Procedure IMG_1259
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Is this happening to all model years or specific ones? And did the becm software get updated with a specific or recent update?
Not sure in all model years, but if it affects me it likely affects at least 21-23 models as well.
I manually update to latest software, but this will eventually come to everyone via OTA. Expect a drop in the SOH reading after a powertrain update, again the battery is still fine.
AllTheThings55
Mesa, AZ
2023 Mach E Select w/AWD
Professional Services (IT)
Maybe this explains my 23.5 having such a low SOH (91) with less than 7k miles….
HughJazzol
Norman
Miami
Thanks again Lee.
Last question, your honor.
In your instructions you mention to leave the car plugged in for 3+ hours after charging to 100%. What's the reason for it?
Thanks again Lee.
The cells need time to top balance and the BECM needs to measure the precise resting voltages to determine an accurate SoC. This can only be done while the battery pack is completely idle (not driving or charging). It can take several hours for the voltages to fully settle down to stable millivolts after current flow.
Just finished the calibration. 2021 Job 1 with the latest OTA updates (which are behind the 24s and 23s). SOH health readout jumped by an entire single percentage point and more than 4% off the value from charge added, charge remaining and battery capacity. That calculation put the number just over 98%, which is closer to previous years' numbers. The final 5% was painfully slow on the 100% charge btw.
Mache_Nor
Norway
MachE LR RWD
Did the calibration in a 23C environment: 91% SoH which is 2% up from before calibration. Energy capacity was 84.04 at 96.14% battery, which would mean it if doing the Lee’s calculation is 96% SoH (84.14 / 0.9614 / 91).
Mache_Nor
Norway
MachE LR RWD
Hmm, seems like there still is some to it about this calibration. I’m currently on a road trip, and tonight I again parked in a warm garage after a day of driving in the 20-80% range. 1 hour after charging was complete I read the following values (car was off, hence limited numbers). On two days I have gone from 89-91.5% SoH on a 21’ job 2 car with 129 000 km driven.
Ford Mustang Mach-E HV Battery Calibration Procedure IMG_1336
rreddy3
Richard
2023 Mach e Premium AWD X
I did this calibration a couple of days ago after completing the return leg of a 500 mile plus round trip. On the return I charged to 81% enroute. 80% is my typical max charge. I figured 81% is close enough for this drill. I arrived home with about 14%.
I drove the car without recharging down to 8% SoCD, 8.5% shown on CarScanner (CS). (12.5% on CS SoC including buffer.) I let the car set overnight before L2 charging at home the following day to 100% SoCD. The charge was continuous, and the car stayed on plug for > 3 hours after the charge. Car is a 23.5 X range with about 6815 miles at the time of the 100% charge.
I noticed the SoH display in CS had sometime within the past 2 or 3 months dropped to 95%, from a consistent 98.5%. My gut reaction was the 95% just wasn't' correct. I didn't know why it wasn't correct until reading @Mach-Lee 's update above.
I'm now in the next phase of the procedure, driving the car to under 50% SoC after the full charge.
The numbers: kwH delivered from ChargePoint 48A = 88.16 kwH
kwH accepted by the car per FP = 82 kwH
efficiency, accepted/delivered ~ 93 %
% SoC added per FP and car = 92%
Calculated useable kwH, accepted kwH/% SoC added,
= 89.13 kwH
[CS display of energy at 100% SoCD = 89.9 kwH]
Calculated SoH, useable kwH/91 stipulated max useable capacity,
based on FP derived 89.13 kwH useable ~ 98 % SoH
based on CS displayed 89.9 kwH energy ~ 98.9% SoH
My takeaways; The battery is fine; I'm not going to worry about SoH display on CS; I like the CS derived 98.9% SoH calc but suspect that's an aggressive number and not the real SoH; That said, I don't know how CS determines the 'energy' number, the numerator in that calc; I am making a presumption that the 'energy' number displayed by CS is its estimate of useable max capacity at 100 % SoCD; Obviously, I could be wrong; Although, to my non-scientific eye it seems to correlate reasonably well with the calculated max useable kwH based on the FordPass statements of accepted kwH and % SoC added.
I'll look at numbers again after driving to < 50% SoCD and charging back up to my routine 80%. My typical pattern is to keep the car between 50 or 60, usually closer to 60%, and 80%. Obviously shallow charges. Mileage is pretty low, so I can go for days at a time w/o L2 at home charge.
One last takeaway, I absolutely love this car. (And, the 8.5x20 Atomic AWZZ black wheels, Pirelli P Zeros AS plus 3 in 245/45 x 20, Eibach anti-roll bars, front camber adjusting bolts, and the Air Design/Ford accessory lip splitter, deck lid spoiler, and under rear bumper diffuser don't hurt, not to mention the euro cargo rings in the back luggage area, longer Bosch wiper blades, and Forscan tweaks, and the front middle speaker replacement don't hurt! Except may the wheels hurt range, but they look good and only weigh 21.5 # each, so who cares.)
