L2 40a overheating
AlpaChino
JB
Indiana
2025 Kia EV9 Land
I have a Grizzl-e EVSE with adjustable output between 16-32-40 amp settings, connected to a 50a breaker. I've used it at the 40amp setting for over a year with no issue.
About a month or so ago I ran into multiple charging errors such as "scheduled charge did not begin" or "charging stopped", typically only after 20-25 minutes of charging. The outlet is cool, the cords are cool, but the "nozzle" connected to the car is hot. Uncomfortable to touch the metal disconnect button.
I stepped down the EVSE to 32 amp and have had zero problems. There are times where I'm returning from a long trip and need to charge as fast as possible, so getting back to 40 amp is a priority.
My car will be getting BC at the dealer tomorrow. What other updates should I request that might solve this? Or is this a common issue that software won't fix?
JGuske23
Justin
Kalamazoo
Mach E Premium AWD extended range
Market manager
It appears this is part of the protection update Ford put in place regretfully. I too am having the same issues and with 39k miles I took need my car charging as fast as possible most days. I hope Ford fixes this and let's our cars get back to 40amp+ ASAP
Sam2084
Madison, WI
2007 CR-V, E4X Ordered
Sounds like an EVSE issue more than a MME issue. It’s hot out, and it may be overheating.
Mrn
Pima County
MMES
Aviation
I would ask grizzly to send me a new piece that includes the car connector if it can be separated out that way. It's usually the hot part that has the defect.
Fixbear
Frank
ADK. foothills, NY
If the 1772 plug has enough resistance that it is making heat, check the pins in the car's port to be clean and bright. I've heard of contact contaminates causing this and you may have to replace the charge port as well as the EVSE lead. The charge port does have a thermistor in it that will cut back charging if hot.
Regulus7
NYC
993 C4 Cab, Macan S, SantaFe, Ice Blue MME GT
Money Manager
I was using a Lectron 40A 15-40 charger for almost a year on my other EV with no issues. The first time I charged the MME I did not have any issues. This weekend was the second time I charged it at home (I mostly charge at the office - free charging!) and I kept getting charging faults. Usually after 10-15 minutes. I disconnected the Lectron charger and used the Ford 32A charger without a problem. It’s too bad you can’t tell the car to step down to 32A if your charger does not support any charge changes. I am probably just going to order a Juicebox 40. But as I charge at work (also 32A) most of the time it’s not a big deal
AlpaChino
AlpaChino
JB
Indiana
2025 Kia EV9 Land
Yep. I had a friend pull codes for me and he found this:
SOBDM : Battery Charger Coupler Temperature 'A' Too High: No Sub Type Information
I'll be advising the tech tomorrow of this discovery, and hopefully narrows it down a bit. I've had the same behavior from other 48amp chargers on the road very recently, so I know it's not my EVSE.
Fixbear
Frank
ADK. foothills, NY
I don't like that the receptacle in the car is not sealed when the door is closed. Chemical fumes or even salt fumes will eventually affect the contact surfaces over time. BMW and Mini use a dummy plug to prevent that.
Bikespace
2022 MME Premium ER 4x
Try cleaning it. The Grizzl-E charge cable (with the J1772 end) looks to be easy to replace as a unit., if they'll send one. But see what they say first.
Raymondjram
Raymond
Bayamon
I recommend coating the charge port contacts with light machine oil. It will not allow oxígen to touch the metal, but as soon as a charge plug is inserted the wiping of the metal surfaces will displace the oil, and will not put up any resistence. The surface cohesion of the oil will return to cover the contacts after the plug is removed.
Mrn
Pima County
MMES
Aviation
The standard coating to keep contacts from oxidizing is dielectric grease commonly used in auto ignition systems, about 6 bucks/tube.
JGuske23
Justin
Kalamazoo
Market manager
I charge at 48A without issue.
What brand do you use by chance? I'm a juicebox and the tech ran her tests with no issues on her side, then scoured the internet to find a thread of people on another site with these same issues since Fords last update.
ChargePoint Home Flex.
