Leaking axle seal
jrdelong1043
Chillicothe, Ohio
2004 Honda Civic
Utility Arborist
I’m at 55k and today I noticed some pooling of oil on my garage floor. We’re all electric, so the culprit has to be my MME (it parks at the same spot). After looking around I noticed the underbelly material was darker in a certain area, but not wet of oil (dried look). I turned my wheels a hard left and right, that’s when I noticed on the passenger around the axle it is wet of grease/oil residue. Looks like it’s been leaking awhile because there is oil residue on other components behind the differential. About 30k ago I had the axle clicking and things were so new the techs didn’t think the axles were bad, and Ford replaced the front motor. Turned out that the motor wasn’t the issue and the axles were faulty. It’s been solid ever sense. Going to take it in to get this leak looked at. At 55k, overall it’s been a fantastic car. Ford has always taken care any issues it’s had. Just thought I’d share this with you all. Here is a pic of the leaking area.
Ford Mustang Mach-E Leaking axle seal IMG_9265
Ford Motor Company
Official Ford Account
Good morning! I would like to take a closer look at this leak issues on my end. To get started, can you please send over a private message with your VIN and the name and location of your local Ford dealer?
jrdelong1043
jrdelong1043
Chillicothe, Ohio
2004 Honda Civic
Utility Arborist
Thanks, I’ll send it!
Neil V
New Mexico
23 Mach3 premium all wheel drive extended range
ICG 600
I just took my 23 MachE 4x in for an EV service and I get home and have a little puddle of oil on the garage floor, so I look under the car and just above the puddle is what appears to be leaking rear axle seal. I have another appointment next Tuesday morning..
Ford Mustang Mach-E Leaking axle seal IMG_9881
Ford Motor Company
Hi Neil V! I can look into your Mach-E's leak concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Mach-E's VIN?
Neil V
New Mexico
ICG 600
Ford Mustang Mach-E Leaking axle seal IMG_0013
And I get it back like this now.. ?
monefe458
Bryan
Indiana
2021 Mustang Mach E 4Ex, 2015 Mustang Gt, 1989 Mustang Lx
Were you guys able to find the culprit of this issue? Looks like an axle seal. Im running into the same issue. Looking at what others have done to fix this.
Ford Mustang Mach-E Leaking axle seal IMG_9222
