Limited to 88MPH
Kelly
Jacksonville Fl
Mustang Mach E GT performance
Sales
For some reason my GTPE will top out at 88 mph and will not go above in highway traffic. Can anyone elaborate on why and how to prevent.
You probably have an oil pump failure in one of the transaxles. Do you have an OBD code reader? That would positively identify whether this is the issue or not. ??
HowietMMEGTPER
Kelly
Jacksonville Fl
Sales
I do I guess I will run it up thanks.
0CO2
0CO2
Philomath, Oregon USA
MME FE
Academic
Are you using your spare key fob? When I use that, I get the same limit, but otherwise (PAAK, primary fob) that limit is removed.
The reason for that is because at some point that spare key was programmed as a "My Key" with that speed limit (88 MPH) associated with that device.
See the Mach-e manual and search for My Key.
excitebike82
Casey
Waco, TX
2022 Mach E GT
Mechanical Engineer
Look for a P0B0D or P0C2A codes. There’s quite a few threads on this. My car ended up with both the front and rear drive units replace and the HVBJB completed to fix.
drives great now though….
Byrus
2024 Mach E Premium
Probably a silly suggestion but did you check your profile to make sure the speed limiter isn't set to 88 mph?
HowietMMEGTPER
Kelly
Jacksonville Fl
Sales
This is probably the most logical thing alongside with the key fob setting.
Just FYI, the car sets its own limit to 88 MPH (100KM/h) when it sees a code for a stalled transaxle oil pump. ??
Clockwork
2024 Mustang Mach-E Rally
It's to prevent you from activating the flux capacitor and traveling back to the future.
MellowJohnny
Christian
YYZ
Solution Architect
88 MPH is a bit above 140 kph...
lesz
Les
2022 Mach-e GT PE
could you also go to your account on ford.com and run a health report and get the same info?
