Little heat verified by data log
Jimbo
Jimbo
US
Premium 4X
More details at https://www.carscanner.info/records/
Once confirming Data Recording>Record Data is enabled, you can also just open All Sensors to record everything (and then only selecting what you want to show when it's time to chart). On another thread, someone reported that didn't work for them (nothing recorded), and it didn't work for me the first time, but it's worked flawlessly since
available_username2
Cmax energi
I heard through rumor that it helps to turn off auto made the heat work at low temperatures. Have you tried that already?
camdenlake
Josh
Kingston, On
2001 f350 CCD 7.3, GT500, Gen1 Raptor, 2021 MME R1
Placebo effect. But slowing the fan down manually your just making less air but it feels like warmer air but still inadequate to heat.
camdenlake
Josh
Kingston, On
Ford has been in touch with me thanks to this post and forum. I hope to have a rep contact me early next week.
Jimbo
Jimbo
US
Premium 4X
camdenlake
Josh
Kingston, On
Guy
Guy
Canada
Premium AWD Long Range
A local dealer has found a glitch, E-Heat turns itself off when you turn on the front defroster. (Max Defrost) A work around is to go in manual mode, turn on the defrost AND either the vent or floor outlet, then E-Heat remains on. In cold climate, never run the fan above 4 or 5 as then the heater is not powerful enough to heat the air.
available_username2
Cmax energi
Like it turns off in a hidden way that it looks like it's on? Or if you actually go in it looks like it turned off and you can turn it back on?
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
If you mean e-heat becomes “greyed out”/ unselectable, I believe that it because you’re being prevented from running max-defrost WITHOUT e-heat turned on.
camdenlake
Josh
Kingston, On
I have not had that but have only used max defrost a couple times and it worked good. But was not very cold yet.
Josh
camdenlake
Josh
Kingston, On
That sounds quite logical.
Guy
Guy
Canada
But if you select defrost AND vent then you could turn E-Heat off? Doesn’t make sense..
camdenlake
Josh
Kingston, On
Max defrost is a dedicated feature designed to give just that max defrost you cannot mix it with anything else or its not max defrost. Ford has had this on vehicles for a while i forget the first one that had it.
Too bad they can't reprogram the HVAC to use only 50% outside air. I think right now it's either 100% or 0% depending on the recirc setting.
Lowering the blower speed will still help because then you're taking in less outside air. It's a balance between extracting enough BTUs from the heater core, and taking in too much outside air to heat effectively. It would be smart if the blower could be programmed to maintain a set vent temp of say 85ÂşF by adjusting airflow.
Doing some calculations, it seems the battery could be heated up about 0.5-0.75ÂşC per minute if all the heat goes to it, which would take about 30 minutes to warm up. Then the cabin would take another 20-30 minutes. So yeah, that's why preconditioning takes 50 minutes. I think the heater is really only sized to heat the battery or cabin, not both. They should really have two heaters or increase the output to 8+ kW instead of 5.5 kW.
