locked and not charging
Crazynyc
Srikanthreddy
Summer@05
Mache
Hi All,
Today strange thing happened came home from work and wanted to get some grocery went near to car its totally dead. unable to open door via key fob or using code or ford pass. when opening ford pass says battery 51% or 113 miles, but not able to open doors or charge. checked the last software update was in july. Any one had the same issue or need guidence.
Tomorrow morning i am thinking of towing the car to dealer.
What year is your Mach-E? This sounds like a dead 12V battery, not a low HV battery. There are some jumper cables inside of the front bumper that can be used to pop the frunk lid open so that the frunk panels can be removed for charging or jumping the 12V battery. Have you tried those? Once you get enough charge into the 12V, the doors should open and you should be able to start the car. ??
Crazynyc
Srikanthreddy
Summer@05
Mache
Crazynyc
Srikanthreddy
Summer@05
Mache
Thank you for your reply.
2021 model which side of the bumper I need to check for cables.how to recognise them
Jumper cables inside of the front bumper that can be used to pop the frunk lid open
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
There is a flap on the passenger side. You can’t miss it.
Ford Motor Company
Official Ford Account
Hi All,
Good morning! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this concern? Thank you!
