Mach E Lower Grille replacement
jmmr0c2
Gol
2023 mack e
I wanted to know if anyone has replaced the lower grille without taking off the entire front bumper.
Ford Mustang Mach-E Mach E Lower Grille replacement IMG_1721 Copy
Ford Mustang Mach-E Mach E Lower Grille replacement IMG_1718
Ford Mustang Mach-E Mach E Lower Grille replacement IMG_1719
phidauex
Colorado
Renewable Energy Engineer
I made a valiant effort to replace that part without removing the front bumper, and failed entirely. The front bumper does need to come off.
jmmr0c2
Gol
2023 mack e
based on the parts diagram, I thought it would be possible. Thanks
phidauex
Colorado
Yeah, it really seems possible, but it is just impossible to get a tool onto the necessary tabs with the bumper in place.
marlamac22
Marla
Las Vegas
Mach E Select
manager
Yes you absolutely can do this without taking off the entire front bumper. My son and I were able to this in about 4 hours (that includes cleanup). The black lower shutter grill assembly was purchased through Parts Geek (2022 Ford Mustang Mach-E Radiator Shutter Assembly) sku 601-563. There were a lot of clips, and we had the car up on a ramp but Ford was going to charge $$$$ to do this work. The part was $367 and our labor.
Ford Mustang Mach-E Mach E Lower Grille replacement Mach E - Cracked Lower Shutter Assembly
Eagertrader
Norberto
Mustang Mach e GT
Realtor
I had the same happen to me on the last storm. My car skidded and plowed into ice and the lower grill + the radar got damaged, and the left side fender got a small scratch. The body shop charged $4.500+ for the repair.
rts5
R Taylor
21 MME First Edition
Educator/Physician
Greetings, I don't know the answer ....but I have a "toothless" MME as a rock took out one of the louvres. When you do get it repaired I'd be interested in the middle drivers side louvre if it's salvageable. I'm hoping to just bend a replacement back into the old one's location. Thanks much. Taylor
marlamac22
Marla
Las Vegas
Mach E Select
manager
Yes I have lost a couple of the louvers too, in fact when we took the grill assembly apart one of the louvers was stuck at the bottom. My son 3D printed 10 of these for me to use, plus I got a ton from the replacement part.
rts5
R Taylor
Educator/Physician
Excellent, would I be able to replace a middle louvre from the outside just by bending it in place? Where can I fond just one louvre, do you have a source?
Thanks so much. Taylor
marlamac22
Marla
Las Vegas
Mach E Select
manager
Hi Sorry, I just saw this post. I have several and can just give you a few since my son can 3d print more. Not sure how to get it to you though.
rts5
R Taylor
Educator/Physician
rts5
R Taylor
Educator/Physician
Greetings, ask so sorry too for my delay.
I would be happy to pay for shipping if you have a spare.
Certainly worth a try. (I'm 48895 zip code)
(I haven't gotten underneath to check access yet but I have to believe I might even be able to bend it in from the front if needed. It's the drivers side middle one. (looks like it's missing a tooth)
Thanks so much for getting back with me.
Taylor
