Murse-In-Airy
- Rod
- Mar 5, 2021
- Chaumont, NY
- Mach-E ER AWD
- Nurse
When you configured ABRP, did you also adjust the settings for speed % above posted limit and the temperature in the road conditions settings?This weekend I did a road trip that was nearly 400 miles for the first time. The route that was provided by the built-in nav on my departure was perfect, this required 2 stops to charge. However, on the return the route wasn't what I expected, although it technically would have worked, this required 3 stops to charge.
I too ran into charging issues on 5 of 7 charging attempts on this trip. Most of my issues were due down stations, units not authenticating to start charging, or extremely slow charging speed (15kw on a 150kw or 350kw station).
Before my return trip I actually tried out A Better Route Planner (ABRP) for the first time. After I configured the app, then compared the results to the Built-in nav, I liked the options it provided much better. I decided to use the route provided by ABRP instead on my return. I was floored by how accurate the results were. My SOC when I reached the first charging station was spot on.
That said, I stand corrected, ABRP is anything but "nonsense" as I originally stated. It really is a impressive tool that I would use again. One word of caution, make sure you manually adjust your mi/kwh in the setting for what you are actually getting. The default values might be too high, especially if you run the heat, drive in very cold weather, or just drive too fast.
My takeaways:
Going forward I plan to avoid taking any trips that require more than 1 stop to charge (or about 200 miles one way). With the roulette wheel of potential issues with charging stations, the hassle with delays and detours is not worth it for me. This longer trip was a great learning experience for me and made me consider things I hadn't before. Lesson learned.
- The built-in nav is fine for trips that only require 1 (maybe 2) stops. The route options when 2 or more stops are needed can be a bit odd. Use ABRP if you have multiple stops.
- If you're traveling to more remote areas always check Plug Share to help minimize to chance of going to a bad charge station. Even when I did this I still nearly got stuck due to multiple stations being down for repairs, or just not working.
- Try and stick to routes that provide more charging station options whenever reasonably possible. Due to #2 you never know when you need take a detour to another charge station.
I ask because I’ve had better luck leaving the default miles/kwh at the 2.73 default. Then adjusting all the other parameters. When I changed the miles/kwh it went wonky on me and wanted me to charge all the time. So I’m wondering what you and I did differently and which would be easier/ more accurate.
