RunningHorse
Hi, seen a lot of posts/discussion regarding the sounds the Mach E makes lately and just wanted to clarify the details and clear up any confusion. So the sounds the Mach E emits can be broken up into two domains, interior cabin sounds and exterior sounds outside the vehicle.
Interior Sounds : The sounds passengers can hear from inside cabin come from two different sources, artificial propulsion sound and electric motor whine.
Hope that helps
Sauce:
- Propulsion Sound: This is electronically generated sound based on real time vehicle dynamics A module takes in input signals for torque, power, and speed then a software algorithm processes the signal values and outputs a request to generate a propulsion sound at x frequency at y loudness. These sounds are broadcast from the internal vehicle speakers
- Can I turn off propulsion sound? Yes, you can turn it off in all modes.
- Is it based on an internal combustion engine sound? No. Engineers researched sound profiles from movies, machinery, the Formula-E race series, roller coasters and amusement park rides. The final Mustang Mach-E sounds include “futuristic sound profile elements with hints of conventional Mustang sound elements"
- Does the propulsion sound change with the 3 drive modes (Engage, Whisper, Unbridled)? Yes.
- Engage Mode: Slight propulsion sound
- Whisper Mode: No propulsion sound, you can only hear the slight motor whine at take off
- Unbridled Mode: Loudest propulsion sound
- What's the point of propulsion sound, isn't a BEV supposed to be quite? It's an option that can be turned off/on as stated previously. Also research shows many passengers in BEV vehicles get motion sickness because of the harsh acceleration (instant torque) and deceleration (regenerative braking). Many people are used to hearing an engine note to give them a sense of speed/slowing down that prepares them mentally however in a BEV you loose this. A propulsion sound helps remedy this issue as passengers who are reading/on their phone/etc. are able to get a sense of acceleration from the propulsion sound.
- Electric Motor whine: In all modes there is also a very slight motor whine sound you can hear emanating from the electric motors. This is a real sound and It's mostly noticeable at takeoff. Listen to the first couple of seconds of whisper mode clip for example.
- What does it sound like?
- Can I turn it off? No, it's a government mandate but you can probably find a way to disconnect the wires to the AVAS speakers if you really wanted to.
- Is it loud? Not really, It's intended to alert close by pedestrians/bicyclists that a vehicle is passing.
Hope that helps
Sauce:
