Larry Paul
Larry
MME-GTPE, Sunbeam Tiger w1970 Boss302, 2002Rav4EV
Roger tobin
Roger
Beaverton OR
2021 Mustang Mach E Premium RWD Extended Battery
I'm in the metropolitan Portland OR area as well. I found it necessary to disable 1PD to have better control over the vehicle as I was decelerating on the slippery spots.
Question for the group: Under the new UI, the 1PD selector seems to do a global change across all of the drive modes. Was this the behavior in the past? (I don't remember it that way. . .)
Ford Mustang Mach-E Mach-E vs Snowmaggedon Feb 2023 1677521959340
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
I know previously (3.5 something) the 1pd was stuck to each drive mode. I know this because out of the blue whilst driving mine decided to Guest mode me and stuck me over to Engage, without 1pd. I caught it fast enough to not run out into traffic. That was NOT fun. Now in 4.1.2+ It appears it's global though all the modes.
Larry Paul
Larry
and the 2021/2022 Ford manual for the Mach E says:
USING SUMMER TIRES
Summer tires provide superior performance on wet and dry roads. Summer tires do not have the Mud and Snow (M+S or M/S) tire traction rating on the tire side wall. Since summer tires do not have the same traction performance as All-season or Snow tires, we do not recommend using summer tires when temperatures drop to about 45°F (7°C) or below, depending on tire wear and environmental conditions, or in snow and ice conditions. Like any tire, summer tire performance is affected by tire wear and environmental conditions. If you must drive in those conditions, we recommend using Mud and Snow (M+S, M/S), All-season or Snow tires.
Always store your summer tires indoors at temperatures above 19°F (-7°C). The rubber compounds used in these tires lose flexibility and may develop surface cracks in the tread area at temperatures below 19°F (-7°C). If the tires have been subjected to 19°F (-7°C) or less, warm them in a heated space to at least 41°F (5°C) for at least 24 hours before installing them on a vehicle, or moving the vehicle with the tires installed, or checking tire inflation. Always inspect the tires after storage periods and before use.
SpaceEVDriver
Planetary Science
I didn't drive the Mustang today, but I did yesterday.
Here's today's accumulation.
We're up to around 12 feet of total snow since November.
Ford Mustang Mach-E Mach-E vs Snowmaggedon Feb 2023 Screen Shot 2023-03-01 at 18.51.28
johnmark
JM
Massachusetts
'22 Mustang Mach-E GT
I also turn off 1pd - was wondering how many others do the same. I had exactly 1 experience with 1pd on ice before deciding not to try that again.
azerik
Snowbowl is on a 322 inch base and it's still falling. At least we'll have water, this year.
SpaceEVDriver
Planetary Science
well that needs a lot of work to take it off
An interesting impact of an EV is that the snow on the hood doesn't melt while the vehicle is "warming up," so it needs to be removed, which means higher likelihood of scratching a visible part of the car.
SpaceEVDriver
Planetary Science
Yep. Got another foot at our place overnight...
TheVirtualTim
Dearborn, MI
I really wonder how the stock GTPEs Pirellis will perform in the cold.
Use of summer-only tires in cold temps (even on flat dry pavement) is highly discouraged.
The rubber is formulated to be grippy in warm weather ... but is stiff and _not_ grippy in cold weather.
SpaceEVDriver
Planetary Science
I hope so. If it doesn't melt too quickly (on the mountains), it'll be great. If it melts too quickly, it could lead to much more dangerous fire season because all the underbrush growth drying out and becoming tinder.
Papapoil
Stéphane
Sept-Îles (QC)
2022 Mustang Mach E Select RWD Grabber Blue, 2017 Focus Electric Ingot Silver
Same thing here. We get very heavy snowfall and I never use 1pd drive in the winter. Too unpredictable when slowing down on slippery surfaces.
johnmark
JM
Massachusetts
Something else I noticed - although this may be particular to heavy wet New England snows - is that the front sensors get snowed over and crash detection is disabled. Which also means no bluecruise although you'd have to be crazy to use BC in inclement weather.
SpaceEVDriver
Planetary Science
We get that here too. It doesn't bother me because I agree: it's foolish to try to use cruise control of any kind in inclement weather. I am not a carwash kind of person, but with newer vehicles we kind of don't have a choice what with all the sensors on the vehicle. I'm not complaining, but it's certainly something different.
