Multiple Alerts / Issues Display
ramesh
Ramesh
Rancho Cucamonga, CA
Ford Mustang Mach E
Hello Mach e Forum,
I have a 2021 Mach e Premium with 20,000 miles. I love my Mach e and have had a lot of fun driving it.
Today while driving, I started getting multiple error messages pop up on screen:
1. Pedestrian sounder fault - service now
2. Service AdvanceTrac
3. Parking sensors fault
4. Pre-Collision assist not available
5. Cross-Traffic system fault
6. Blind Spot system fault
7. Reverse Brake Assist not available - see manual
8. Advanced front lighting features temporarily unavailable
In addition, I have:
a. ABS - lit up on screen
b. Driving mode - can’t select any of Unbridled, Engage or Whisper
c. Steering seems tight
All these happened today, within a 2 minute stretch and now continue to pop up.
I tried a hard reset / Factory Reset, but it has not solved the issue.
I am looking for any suggestions to resolve the issue.
Please help. Thanks in advance. ??????
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5743
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5742
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5741
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5739
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5736
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5740
Ford Mustang Mach-E Multiple Alerts / Issues Display IMG_5738
AZMMESTAR
Herb
Metro Phoenix
2024 MME Premium Star White RWD ExtRange
What is the status of your 12V battery?
Thats not your 12v battery level. That’s your HV battery
May be @Mike G can check your vehicle id to see the 12v battery level remote.
Share your vin
Since the car is at 35%, that is the 12v.
Willymy
William
Scottsdale, AZ
2021 Mach e Premium Ext Range
I have been unable to find where the 12V status is. Can someone help?
tbrumleve
Tom
Oregon, USA
Mahmood
Mahmood
Eggpt
Ford Mustang Mach e
Dentist
Hello Mach e Forum,
How you were able to solve it and what is the cause of the problem
Mach e Mark
Upstate NY
Mustang Mach e. F-150 Powerboost
Go to Harbor Freight and buy the cheapo Viking battery tester $45.00 and you'll have one. Or. Go to one of your nearby auto stores and ask them to check it for you. Make sure you know how to expose your battery first so it's done correctly. (See Mach Lee's 12V battery write up here on the forum. Search for FAQ 32744 or follow this link. Make sure you start at the beginning. https://www.macheforum.com/site/threads/12v-battery-faq.32744/). Do not buy the replacement battery from the auto parts store, it will be wrong for your car. Get the Motorcraft BAGM-H3 from a dealer near you. Should be around $120.00 plus the core charge. If you are handy and want to change it yourself please read Mach Lee's write up or---- You may just need to desulfate your existing battery. I use a BatteryMINDER model 2012 and it does the trick. Again, read Mach-Lee's primer on the 12V battery.
dcohen
Fairfax, VA
Honda Clarity, MME on order
I just had the battery replaces and the Headlamps switched this morning and as soon as they drove off after dropping it off, I have the same behavior. Basically any/all safety/driver assistance system throws a fault and is disabled. Pretty sure after the work, they just handed the keys back instead of performing any post replacement procedures. Hopefully they resolve it quickly.
