New FordPass view?
pdxzzr
Oregon
Grabber Blue Mach-E First Edition
Attorney
Got the app update, looks a little cleaner, but … initially there was a “Start” button at top right of main homepage. BUT is it no longer there.
Ford Mustang Mach-E New FordPass view? IMG_2052
Any thoughts on where it went?
Why is charge paused at 88%? Might have to do with that.
You might have to unplug and plug in again.
Mach1E
Where is it? Is it the fan picture that says, “climate”? If so, that’s misleading.
Technically it would be more accurate as it doesn’t actually start the car, it just runs your climate controls.
pdxzzr
Oregon
Attorney
Paused at 88% (set to 90) because my home ESVE is set for time of use charging, so charging doesn’t start until 10pm or 12 am
So how could it start charging if the EVSE won't allow it? That's probably why the button isn't showing up, since it wouldn't do anything.
Snakebitten
Coastal Texas
2023.5 Mach-E
On mine the Start button in FordPass will perform it's circular progress graphic for a few seconds while it sends the command.
But since the EVSE itself is NOT going to send a charge to the car unless it receives its own command, the FordPass button returns to "Start", rather than "Stop".
hartmms
Phoenix, AZ
Mach-e GT-PE, Ram 2500
engineer
I'm on android 14 with the new beta 5.0 fordpass app. I don't get the "service" button/icon on the bottom of the app consistently. I saw it once after I did a force stop of the app, but it disappeared again. Most of the IOS screen shots I see always have it visible. Is this expected behavior?
Also, the "location" button is gone. Again, I saw this once, but it's not currently displayed. I like using that to see exactly where the car is in a parking lot if I don't pay attention to where i parked. I also don't see a method to "refresh" the view like the old app could do with a swipe down. Is this feature gone now?
I do like how the hood and tailgate buttons are instant once you go into the controls section. I could never get the 3 second touch method of the old app to work on the first try before.
No, I'm not going to call it a frunk. It a hood that happens to have storage under it. :)
