No display!
PhillyBear
Andy
Ontario
2022 Ford Mustang Mach E Premium eAWD
Anyone else have this issue?
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Is this the main screen or the one behind the steering wheel or both?
Try rotating your headlight switch to "Off" and wait a few seconds. Then rotate it back to "Auto." 😊🐩
Thor2j
Colorado
Mach E GT , Ford Raptor
If it's main screen and completely dead I had the same thing. After a month a module had to be replaced . Message me if you want more details.
louibluey
FE "Louibluey" GB
If it is the small driver's speedo display in front of the steering wheel, usually lifting the 12V LVB negative battery terminal for a couple of minutes will usually bring it back to normal operation. I think one of the software updates solved this problem.
If it is the large center Sync display, try the combination of volume down and right arrow keys on the steering wheel together for some seconds for Sync reset.
There are many threads to search for, for both of these problems if you are looking for more details.
Polar
SBJ
PNW
2021 Select RWD SR
Reset Sync - volume down and track right on steering wheel hold for 10 seconds - worth a shot to try if your screen goes blank again.
