Ya, several times, also have an unused 240v circuit in second garage bay I tested on as well. Same issue.Have you at least manually tripped the breaker and reset it? My Clipper Creek faults from time to time and it's the breaker reset that gets it back in order.
You should just drop by the dealer and give it a quick test. Also have you ever attempted to charge on a public charger? This should narrow things down. Perhaps dealer will have a portable charger to test. Finally do you know anyone who has a Mach and maybe use there charger?Ya, several times, also have an unused 240v circuit in second garage bay I tested on as well. Same issue.
Car is daily driver for wife, so once it is avail and works with dealer hours, we plan to test. Charged on public charger with no issue before this situation arose. Will try again if dealer option fails. Only seen one MME in town. No idea who owns it.You should just drop by the dealer and give it a quick test. Also have you ever attempted to charge on a public charger? This should narrow things down. Perhaps dealer will have a portable charger to test. Finally do you know anyone who has a Mach and maybe use there charger?
