PAAK Pro-Tip
cdr_taggart
Ethan
San Jose, CA
Mach-E First Edition
I've found that turning on the car without holding down the brake pedal, waiting a few seconds, then turning the car all the way on works when you get the "no key" message on the first attempt.
JerseyMike
Delran New Jersey
Mach e Premium AWD extended range
i have noticed that it seems to work better when approaching the car from the front. lights turn on, pony light is projected and first time hitting the door button works. ford sent a message saying make sure Ford pass is open, phone is out and you are connected blue tooth to vehicle...easier to have actual key..
NoMoShocks
Larry
Camas, WA
2017 Chevy Bolt Premier EV, 2018 Mitsubishi Outlander GT PHEV
Electrical product safety engineer
Yes, that is because the on board computer gets real board while you are away and it may be playing Solitaire or Candy Crush when you come to start it.. A gentle tap on the shoulder is better than shaming if for multi tasking like that. Thanks for the tip.
agoldman
Charleston, SC
Anyone notice that the little lock symbol on the front drivers door sometimes doesn't respond for many seconds after you turn off the car and close the drivers door? Sometimes I have to hit the one on the rear door and sometimes use the numerical two digit lock code instead. The little lock thingy seems to have a bit of a delay when you close up the car. maybe it's just mine..
