Preconditioning when unplugged
mikeynags
US
2021 MachE Select
Network and Security Engineer
Just hit a 2nd schedule for today (plugged in) and no issues. Weird how random it is.
Shayne
Northern Ontario Canada
2021 MME4x Prem
I have a random schedule and fire off a new departure time all the time. Have one and modify it. Has been working here flawlessly so far this winter on PU 6.8 and FP 5.11 at the moment. 6.14 for the OPer.
@Mach-Lee noted that it is the car all by itself when plugged and nothing comes from ford servers? Unplugged it does need servers? If that is true it has to be the car sleeping too sound or it never got the info? You can check the FP info made it to the car in the car. Would be nice if both just worked with no service and when their server is down. Schedules and timers have been hard for mine.
What is your new and what is your old? 2021 MachE Select in bio old?
Taz
Taz
Jørn
Norway
Ford Mustang Mach E 2021 FE
IT-Consultant
Seems to be working "ish" again.
Tho it does not say preconditioning, only starts HVAC.
And starts it when it's supposed to be done. Wierd.
MadMatt
Montreal
2024 Mach E Select AWD
pre-conditioning should never happen unless your plugged in. you are at work at this point right?
I've had issues once with FordPass and everything was solved by disconnecting the 12v in the car for a minute. Let every module go through a proper reboot. You never know when one of them is dealing with a software bug.
  • Like
Reactions: Taz
