Range
Jacques
Jacques
Westmount Quebec
Mach-E premium, AWD and extended range battery.
Does anyone know how long would it take to charge my Mach-E from 80 to 95 per cent on an AWD Premium model with the long range battery?
Spooky
Bob
Midwest
Mach-E
No way to answer you without knowing what charger you are talking about. Different chargers have different speeds. Ford mobile charger plugged into a 120v would take a lot longer than same charger plugged into a 240v which takes a 10-15% longer than a 3rd party 240v charger like the Chargepoint which would take longer than a fast DC charger at a gas station / grocery store / etc. which those also can be wildly different.
Also depending on if you have the update or not charging at a fast charger either slows down at 80% or 90%.
Roughly 45 minutes to an hour I think is what I get at home with the ChargePoint per 10 ish percent. Most of the fast chargers around me take me from 30% to 80% in about half an hour or so? Never paid that much attention to it.
Jacques
Jacques
Jacques
Westmount Quebec
Thanks. I omitted a key piece of information, I was referring to a fast charger.
With the updated charging curve, 80 to 90 is at 44kW, 90 to 95 would be at 34.
About 20 minutes.
Jacques
Jacques
Jacques
Westmount Quebec
Thanks, that was very helpful.
