Rear shelf on the high position causes weird issues.
leeman
Outer space
2021 Mach E GT
Hey folks when I drive my GT around town and I have that shelf in the back hatch area on the top position and I don't have anything in the back any little bump I hit causes this thing to bounce up and down crazily. I've seen people post where those plastic pieces that hold it up and broken been careful not to put too much weight in the back due to that. Even at the lower position I get a lot of vibration from the rear suspension behavior I'm sure this is normal has anybody figured out a way to quiet that down or add a top piece to hold the shelf more firmly in place etc. Yeah asking if anybody has any ideas on that thank you.
You must not have it in place properly. Is the edge by the bumper down (proper), or sitting up on top of the back edge?
leeman
leeman
Outer space
2021 Mach E GT
I will check thank you
RedDragon
22 Mach E AWD Premium Ext Bat - Rapid Red
i have the ford cargo mat on top of the rear insert. Everything is in the low position. I dont hear anything. The cargo mat is a good weight
I do also.
