Rear washer not working
Mach Al
Al
Massachusetts
Mach e
Anyone have their rear washer stop working? My dealer said they are having a hard time finding the problem. I have to bring the car back so they can take the frunk apart to see what is causing the issue. They said they will need the car for two days minimum to figure it out. If you had this problem, what was the issue and did it take a few days to get it diagnosed?
geeklifer
Southern IL
2023 CR1, 2020 Niro EV, 2025 Equinox RS
Notice any fluid leaking around the hatch? That would suggest it is disconnected near the sprayer. Do you hear air bubbles or fluid up above the driver's door when you try and use it? The line goes right by there.
The only issue I've had with it is the body shop fixing my repair forgot to connect the end of the line.
Mach Al
Al
Massachusetts
Mach e
No leaks noticed. I do not even hear the motor trying to pump fluid. I am thinking it may be a motor or electrical since the motor is not working.
Glasgow, UK
Mach-e ER
OH2AZ2OH
Dublin, OH
Mach E 4X
Similar to OP, except my front washer is not working. Rear washer and camera washer (I have a 2021) do spray, though.
Mach Al
Al
Massachusetts
Mach e
Dealership said it will take days to diagnose. Waiting until next week since it is not critical. I don’t think it’s a fuse since it took them a few hours already and they didn’t figure it out yet.
