rear window washer switch?
GENE T
Gene
New Yurk
2021 Mach E
my rear widow washer is not working. is the switch the same switch as the front windshield washer?
timbop
yes, but instead of pulling it toward you, you have to push it away from you. If it's the first time you're using it then it ight take a few seconds for the fluid to get there from the resorvoir
GENE T
Gene
New Yurk
2021 Mach E
Thank You!!! Had no idea.
Manual? What is this thing you call a manual?
stoomy
Brandon
Maine, USA
Ford Ranger
engineer
Does the rear washer use the same reservoir as the front?
markboris
Sonora, CA
