Reliable charging / almost stranded
I had a white lab growing up and never understood this. It's not like a pale pale yellow.
It’s the same genetically as a more yellow Lab, just that the dilution gene combo is a bit stronger. I have seen a number of very pale Labs in the ring that qualify as “yellow” but look more white. 😁🐩
jmcbrew
Jesse
Annapolis, MD
2023 Mach-E Select RWD, vapor blue
On a business trip to York, PA, I draped an extension cord out the 2nd floor window of our hotel and plugged my Bolt in overnight. I used the outlet for the AC unit, which we didn’t need to use. The only other charger in town was a single 25kW unit at a Harley Davidson dealership. It worked out fine, and gave us enough charge to get back home the next day.
MachhE-CT
Connecticut
Mach-E 2024 Premium AWD Rapid Red
PlugShare is your friend. ABRP
Is also good. I don’t use it for its driving instructions but I do use it for planning and it is good for that . You can use the free version for planning. Also I use Apple maps with the EV extension.
markboris
Sonora, CA
Technically, the breed standard recognizes three colors: Black, Chocolate, and Yellow. https://thelabradorclub.com/labrador-breed-standard/ 😁🐩
Ok, Steve, yes you are correct. My breeder breeds 3 different Yellow labs. White, Blonde and Yellow. I've had the others including Brown and Black but Riley is my first White. They've all been great and Riley is probably my favorite but not sure I would do White again. White fur in a dark interior car just does not mix. 😊
