Repeated Charge Faults
Ming
my faults happen more often now after couple of days no issue charging > 2 hours. now it faults out around 30 minutes more or less...
ordered a Tesla Wall charger, should have it installed this weekend, I'll see whether the car still faults out on it, then know it's the car or charger.
Tesla wall charger installed, and 2 charges so far without fault. So quite likely a defective ford mobile charger.
buckbabes
Manny
GLENN DALE, MD
65 mustang, 17 mustang, 21 mach-E
It's might be the outlet you are plugged in to. I used to get that error all the time in my old plug in electric. When I started charging from a different outlet on a different circuit I never got an error again.
kennethlent
Kenneth
Victorville,CA
2017 Ford Mustang GT , 2021 Ford Mach E
They Dealer gave me a new Mobil Charger a week ago as so far no more charge faults or reduced charging
macheavelli
FL
2021 Mach-e Premium
update! Charge faults appear to have been resolved!
Check out service notes in attached invoice for specifics on work performed.
Ken --- are you able to ask your service rep which specific steps were the ones related to the charging issue? The work order isn't super specific on that.
Johnny572
Mach E GT performance
The last 2 days I’m getting charge fault errors and it’s charging slower then normal. It’s been charging perfectly since November. Hopefully the dealer can get me soon. I’m very nervous I can’t charge.
Ford Mustang Mach-E Repeated Charge Faults E6FF443D-C664-46E3-B735-B1506C3D19FC
Ford Mustang Mach-E Repeated Charge Faults EC483E1E-A3FF-4BBB-9E3E-D0E78CB9548D
If you are using the included Ford Mobile Charger, try blowing a fan on it while charging until you can warranty it at the dealer. Recommend upgrading to a larger wall-mounted EVSE for greater robustness in the heat. If you are using a good wall charger, then you may need a new charge port if it's overheating.
Johnny572
Thanks for the info Mach-lee ! I’m using the Ford unit. I will try the fan trick to add some miles!
Gimme_my_MME
Dearborn
When it has the issue are the amber and blue lights pulsing on the charger?
Johnny572
No, but in the past I had the amber/blue light and I would unplug/plug the outlet and it worked fine. Now it’s blue and red light on the car.
Ford Motor Company
Official Ford Account
Hello, John! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this charge concern. Thanks!
1969Camaro
Scottsdale AZ
2021 Mach E Premium, 2018 Prius Prime, 1969 Camaro
I had several faults from the heat. Installed GrizzLE and not one fault since. It's the Ford supplied EVSE.
macheavelli
FL
2021 Mach-e Premium
I bought a new Ford mobile charger to see if that fixed it … one week in and so far so good. I wonder if the dealer will just take the charger in for service to figure it out vs making me take the whole car in.
PonyTail
Rhonda
Beaumont CA
2021 Mustang Mach-e Premium RWD Red; 2018 Lexus es
After five months and 8,000 miles of flawless charging at home with our Ford charger, we suddenly started having charge faults and, when it does charge, it’s charging at the 110 rate instead of the 240 rate, so like 10 miles for every hour of charging. When he installed the 240, because of adding a pool and solar to our house, we didn’t have enough room in our box and because of supply issues he has not been able to find the quad breaker that would solve our problem. He used one of our two AC breakers. We have two AC units for the house. It started to get hot and so he came over and reactivated the second AC unit and put the car charger on what was the oven. I don’t know much about this so if what I’m saying sounds bizarre I probably have something wrong. Anyway since he did this last change, the first time we tried to charge we started getting charge faults and charging at the slower rate. He stopped by again today and he is certain that everything is correct And that since the car charged fine at Chargepoint, he thinks the charging cord is damaged. Maybe a surge damaged it.
Dogtoy
Matthew
Seattle
Mach E
Same issue. Really struggles to make it to 90% when really low as once a week or so it will fault.
