Reverse camera beep sounds "different" suddenly?
shadowsjc
NJ
2021 Mach-E Premium AWD + Ext Range
Not really sure how to explain it, but suddenly today my "beeping" when I'm reversing and getting close to the car behind me sounds different. Like the pitch is off, and/or it sounds muffled. What could be causing this? Hardware issue? Software?
This happens when the car decides to play the alert sounds through the IPC instead of the audio system. If it goes away after turning the car off and back on, don't worry about it.
Brutakus
Vancouver WA
Star White Mach-E Select AWD Comfort/Tech Package
Ive had this happen a few times. Either reset Sync system with the volume and skip keys or fully restart car (turn off and walk away for a minute or two)
shadowsjc
shadowsjc
NJ
How do you reset with the volume and skip keys?
Mirak
Kansas
Ah…. so that’s what’s going on. This happens occasionally to me. Another weird little gremlin. Does not appear to affect performance.
shadowsjc
shadowsjc
NJ
I restarted the car after a couple of hours (and also tried the soft reset of the screen), but the issue persisted
