Setting Auto dimming Headlights
Raja777m
Raja
Indian Land SC
2014 Mercedes Benz E350 4matic
Software developer
Well that’s my point. No one needs to see 400ft in front of them going 10mph. At 30mph your going 45ft per second, low beams should give you several seconds of reaction time which is fine in most driving conditions.
Only the “auto” feature turns off under 32mph. You can still turn them on yourself if you feel the need to in a certain circumstance.
Nah, too much work, just make it work always like rest of the cars do.
agdad
agdad
Derek
78155Ray
2020 Ford Edge
Tell that to the wild boars trying to commit suicide on our vehicles out here.:p
personally, I want that road flooded with light so they stay away. ;)
In Texas farmers are allowing us to hunt wild pigs from a helicopter using ar15's
Most fun Ive had in decades.....everyone wins......except the hogs !
Motomax
Max
VW GLI, 4Runner
Most if not all brands have a minimum speed (btw your Mercedes’ deactivates below 16mph per the manual ?). It’s just common sense. I feel bad for your neighbors and pedestrians that have to deal with your high beams when you’re driving through neighborhoods at 20mph so you can see the birds in the trees ?
Raja777m
Raja
Indian Land SC
Software developer
1. If there are pedestrians, there would be lights on 45 mph roads
again, you're fixated on slow speed point. Let's agree with you on it. What about high speed?
Motomax
Max
VW GLI, 4Runner
Because my initial response was to your comment about wanting auto high beams at slow speeds for when you’re “searching” for something. It works at high speeds… it’s a minimum speed threshold. I’ll give you that it’s not the best functioning auto system (much like most of fords software). I usually find it activating when it shouldn’t vs not activating when needed but in either case just push the turn signal stalk away from you. Not that big of a deal.
