luckie
- Doug
- Apr 6, 2022
- Michigan, USA
- 2021 Mach-E Silver AWD Select SR, traded for, 2025 Mach-E Green AWD Premium ER
- Professor
I have an ongoing issue with my 2025 MME. I can tell it is happening when Ford Pass displays "Starting Charger" and just keeps displaying that. The car goes into a loop of trying to start charging and then immediately stops, repeat, repeat repeat...
First experienced in August, still pops up regularly. It seems to be a software glitch. Every week or so, at home, plugged in, instead of initiating charging at my preferred charging time period 11pm-11am, the car gets into a loop where it tries to begin charging and then immediately stops, waits 30 seconds and then again tries to begin charging but immediately stops. This just keeps happening throughout the night until the 12V battery is drained enough to cause the big high voltage battery to be used to charge the 12V back up to a reasonable level, etc, and loop continues on, and on.
I first noticed it in August a few weeks after bought the vehicle, after a night I thought it was charging, the next morning I had the alerts on Ford Pass about low 12V issue ("Electrical System Drained Service Required") and I went out to observe the ongoing back-and-forth looping, "click" - "clack," lights & sound, repeating, as my charger tries to start and then stops, and the synchronized blue ring of lights beside the charge port starting and stopping, again and again. I unplugged and found the car could charge elsewhere and was fine if the preferred charging times were erased. Thus decided it was a software glitch.
Sometimes its fine for a week or two, and one day this might start immediately when I plug in at 6pm after getting home from work. Other times it does not start when I plug in, it is fine until 11pm when the preferred charging time starts, and then it starts looping.
If I get in the car and on the SYNC screen, I remove any "preferred charging times" at my home charging location (or go charge at a new location without preferred charging times) then it works normally. If I then add back the preferred charging times, they actually work fine for a few days or a week until this happens once again.
Ideas/suggestions are welcome, please. Thanks in advance.
Doug
Doug
