Suspension rust
JVMME
Monmouth,NJ
Mach E 2021
Motion Picture lighting tech
I have my MME for over a year in the Northeast. I just noticed rust on the suspension. Should I be alarmed?
Thanks,
Ford Mustang Mach-E Suspension rust IMG_2112
Ford Mustang Mach-E Suspension rust IMG_2111
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Jeez, not another problem. I don't know if this is an issue. Anyone have any insight?
They neither paint nor plate the half shafts. That surface rust is normal. If you don’t like it, your only recourse is to remove the rust and paint it yourself. It sux, but that’s the way it is. ?‍♂?
21st Century Pony
Martin
Arlington, Virginia
I have my MME in the Mid-Atlantic since mid-May. It was manufactured in mid-March. I crawled under the MME in late March, and my half-shafts looked exactly like the OP's, already.
Sam2084
Madison, WI
2007 CR-V, E4X Ordered
That’s the driveshaft and it’s rusted from the factory.
SWO
MD, USA
This, it's normal. Body rust and galvanic corrosion are what you need to watch out for.
JVMME
JVMME
Monmouth,NJ
Mach E 2021
Thanks forum friends for passing some good info.
Totally normal. Those axle shafts are made from a special type of steel and it is best to leave them natural. They form a thin layer of rust and it becomes a protective layer. Don't brush, sand or scrape it off. Leave them like that and you will be fine.
Mine are just like that, so echoing what others have already posted.
Ford Mustang Mach-E Suspension rust 1660502374877
