Tailgate Stuck
jnthn98
2021 Mustang Mach-E
Hi fellow MME owners,
I was wondering if anyone has experienced a stuck tailgate (from opening) before? I am the original owner of a '21 Job 1 Select with tech package. My 3-year warranty is expiring this month and this problem that popped up yesterday is causing some concern.
When I tried to open my tailgate/trunk via any methods (remote, tailgate button, kick-to-open sensor, center screen), the tailgate tries to open, but gets stuck after moving like a millimeter. I heard the chime with 3 (or 4 cant remember) beeps. The same chime as if the tailgate hit something (like a low ceiling garage). However, I was outdoors and nothing was blocking the tailgate. There's also nothing in the way inside the trunk.
After trying to open it like 20 other times throughout the day at different times, I had some success. Some times it opens normally, some times it opens with a loud "thud". Obvious thing to do is to bring it to a dealer ASAP before warranty expires and hopes that they can reproduce the problem, but please let me know if you also had the same problem.
Thanks!
methorian
Roanoke, VA
IT Admin
I've had issues with my liftgate for a few months now. It will not open at all while charging, and only via button/FP/keyfob when not charging (the button in Sync doesn't work).
Occasionally I'll get the chime like you've mentioned, other times not. I checked codes via ODB port and sure enough there's some logged for the liftgate.
It's going in to service this week to hopefully fix (and do the HVBJB recall while it's there).
jnthn98
2021 Mustang Mach-E
Thanks methorian for sharing your experience! Yesterday, I was able to make an appointment at the dealer in two weeks, which is right before my warranty expires. Unfortunately, my liftgate decided to be normal functioning yesterday (not even the "thud" noise). Hopefully it acts up at the dealership in 2 weeks. Do you know if the OBDII codes are retained for a while? Basically, I am wondering if the tech can still pull the codes that are ~2 weeks old.
methorian
Roanoke, VA
IT Admin
Yea, they'll be logged there until cleared, so no worries!
Ford Motor Company
Official Ford Account
Thanks!
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
var23
Duane
Missouri
2022 Mustang Mach-e GT
Information Technology
I'm experiencing the same issue in my 22 GT. I can get it to open when it moves that millimeter by just grabbing it and forcing it up manually.
It's not consistently happening.
BayPoodle
Megan
RI
2023 mache premium
Have you tried resetting your 12v? It solved my liftgate issue.
var23
Duane
Missouri
Markymax
London
Mach e
Hotel
Thanks!
Hi
Did Ford ever come back with a solution as I have an identical issue in my mach e extended range 2021 model. my local dealership after putting in for diagnostic suggested replacement of the power struts that raise and lower the tailgate. I would of thought it was another issue?
Thanks
Teslaeata
Nottingham, England, UK
Thanks!
I’ve just resolved this exact same issue.
I changed the tailgate latch which cured this fault.
The part cost around £230 and is easy to fit with no programming necessary.
Hope this helps.
Teslaeata
Before I renewed my faulty latch I interrogated for DTCs via OBD and found nothing relating to this defect.
Sadly, if it don’t play up at the dealership my experience is they’ll say no fault found so won’t do anything, typical of faults which are intermittent to some degree.
Good luck, hope you get the fix under warranty.
Teslaeata
Hi
Thanks
It is!
Markymax
London
Mach e
Hotel
Thanks, I let dealership know
Teslaeata
Interesting thing is, the kick-to-open function works better than I can ever remember.
Therefore, I’m inclined to believe the latch had become faulty nearer to when car was new.
Looks like it became “lazy” and wouldn’t always respond to the kick-to-open command when operated and latterly more often than not was failing to respond to any commands including from key fob or button.
The new latch sounds responsive and like it never did before.
Markymax
London
Mach e
Hotel
Dealership is not very responsive at the moment they are still convinced it's struts despite all evidence pointing towards latch.. So going to ask another dealership despite them having struts on back order
