SirronD
- Mar 27, 2021
- SF Bay Area CA
- Mustang Mach-E FE
I regularly charge at home to 90%, and have the charger settings for home to max 90%. Normally, this is working perfectly.
However, I am driving on a long trip and need to charge to 100% before starting out. I press the "charge to 100%" on the Ford Pass app. The app says it is charging, but it is not charging. I tried this several times, but the car refuses to charge past 90%.
Eventually, I had to go into the car and change it's "home" charger settings to max 100%. And now the car is finally charging.
While I had to do this as the only option for now, it is not a really good option. When I return from this road trip, I will have to remember to reset the charger settings.
HOW do you get a "temporary" 100% charge without needing to modify the charger settings?
