Bodyshopguy
- Jeff
- Apr 14, 2022
- Pasadena
- 2022 Mach e GT/2020 BMW 750iM/60 Vette/12 Wrangler
- Collision Center(s) Owner
Thought the disassembled pictures before were bad enough. I thought wrong.
edit: I was t-boned in November and the frame was dented. They have to take out the battery to weld, which is why the car looks like this.
Wow... that's a long time... I'm assuming the inner center pillar damaged... the reason for removing all the outer panels. The inner center pillar is made of Ultra High Strength Steel... it's not repairable... in fact, if you try to repair it, it might tear and if you heat it up, it'll turn into mild steel and lose it's integrity. They've done a good job of protecting the interior. That would have been a 30k repair in one of my shops. That's a lot of work... The only good part... as soon as all the panels are removed... It's faster going back together... the tough part is almost over... Jeff
