TPM
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 1
Guest
2023 MME GT.
Yesterday I was on the freeway maybe 65mph +/- and a TPM warning popped on. Nothing about being low pressure just to have it checked. I safely pulled up the Ford Pass app and also an error. Basically showing the left rear tyre just blank.
About 10-15 miles the error cleared itself. Should I be concerned or just let it go?
Your thoughts?
markboris
Sonora, CA
2023 Mach-E GT.
Your thoughts?
Not sure if you should be concerned or not but I never have been. Has happened to me probably 10-15 times in the last 3+ years of owning a Mach-E. Never had a tire with low pressure when this has happened. I think it is one of the TPMS just not communicating with the BCM but who knows. If it was persistent and the warning stayed for days, then I would have done something about it.
Guest
Thank you
It's TPMS.
If you get a missing value, take out your tire gauge and check the tire. If it's fine, and the missing value doesn't come back, then you may have a bad sensor.
Guest
It's TPMS.
I’m not allowed to mess with stuff like that haha
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Stop by Discount Tire at Thrasher corner. They will check the TPMS for free.
