Trailer Hitch Install
Wednesday
US
2024 Mach E Premium
I recently had Uhaul install a trailer hitch on my 2024 premium Mach E. Does the cut out on the fascia need to be covered. I live in a winter area and I’m concerned about road grime
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
What cutout?
Keep in mind that the US MME has a 0 tow rating.
SteveMach-ee
Mass
2021 MME Select AWD, 2023 Ariya Venture+
How much did they cut away? What hitch was installed? The bumper cover and mud guard(diaper) should leave no or minimal gaps. The front and rear just can be bent in with no cuts. Also remember that area is exposed from the side anyways. I try to hose that area down every week or so in the winter.
Ford Mustang Mach-E Trailer Hitch Install 20250505_125036
SteveMach-ee
Mass
What cutout?
Yes, and it is likely because Ford has not characterized/certified it for stable towing at highway speeds in the US. Structurally the Echo Hitch install is great and other hitches brands are probably fine. From what I see on all the forum hitch install threads I think the majority are using hitch bike carriers or only doing local light towing. I certainly would not tow a heavy boat on the highway.
tbrumleve
Tom
Oregon, USA
Ford Mustang Mach-E Trailer Hitch Install 1749926924447-79
I have one like this, there is no hole.
Wednesday
US
2024 Mach E Premium
My initial comment was confusing. Uhaul made the rectangle cut in the fascia to accommodate the hitch. The cut is not flush against the hitch and looks like road grime can get under the fascia. Does the fascia need to be flush against the hitch to protect anything. My hitch is only for my one up biker rack. I feel I may have made a mistake getting this hitch.
Wednesday
US
2024 Mach E Premium
This a picture of the cit out and hitch
Ford Mustang Mach-E Trailer Hitch Install IMG_1003
Ford Mustang Mach-E Trailer Hitch Install IMG_1006
SteveMach-ee
Mass
Look under, you'll see the hole around your hitch.
Sure a hole cut but no gaps more than 1/8" or less, at least with the Echo Hitch, and done carefully. Look at the photos above. This is what OP is talking about.
Looks like the UHaul installers were really careless. I would not be happy with that install which is why I usually do these things myself. I would try to figure out a way to cover the gaps.
SteveMach-ee
Mass
I wouldn't feel bad about that hitch. It does extend from the bumper further than the Echo Hitch which is better for a 1Up (D'Equip) bike rack. I think you will be able to store the rack in the fully upright position. The EchoHitch needs an extension or the rack needs to be stored at an angle.
If your '24 has the kick to open hatch like mine definitely remember to disable it!
