Update causing AC issue
jvzero
Jason
2023 Mustang Mach-E (Premium)
Forgive me if this was talked about already, but is anyone else in the wild experiencing the following issue?
For the last week when I start my vehicle the AC is turned off even though it was turned on and running prior to turning off the car. It’s always remembered that if I had the AC running let’s say on speed 3 and turned the vehicle off, then the next time I turned it on it would remember this and AC would be back on at speed 3. I hope I’m explaining this correctly.
My mach e recently updated to 6.8 and latest update I received yesteday is “Priority Update 23-PU0725-CLM-FX”. The issue above is still present.
I have a 2023 Premium RWD STD Batt
jvzero
jvzero
Jason
@CarGuy11 I do not have it on auto, but prior to some recent update it would stay on whatever I previously had it set to.
Example prior to recent updates:
1) I have AC on, set to recirculate, set to low temperature, and set to 3 fan speed
2) turn off Mach e
3) turn on Mach e
4) AC remembers previous settings and is ON and running at those settings
Example after recent updates:
2) turn off Mach e
3) turn on Mach e
4) AC did NOT remember previous settings and is actually turned OFF
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Honestly its best to keep on Auto for efficiency. Just adjust the temp up or down for your liking. I keep in Auto 70deg & lowest fan speed & its great.
jvzero
jvzero
Jason
@CarGuy11 I hear you. I’ve tried using Auto and it’s not to my liking. Not a fan of the variable fan speed fluctuations. Thanks for your input.
Regardless tho this is kinda off topic. Using Auto is not the solution to a previously working functionality of the way above I described how it used to work. I’m just curious if others are experiencing this issue I described after recent updates as well.
milepost1
harold
bonney lake
Carbonizied gray - FE
Not sure why, but everytime I get update a/c is always off on next start.
jvzero
jvzero
Jason
@milepost1 - this issue only happened to me after the 6.8 update and continues to occur everytime I start the car. Basically, AC is OFF after starting the car up. I’m in South Florida so we use AC around the clock!
