vLinker MC+ OBD
Tronjo
Nick
Canada
Mach-E Premium 2025
Will someone know why Car Scanner will not populate all fields like on the attached screenshots? The OBD is Vgate Vlinker MC+ connected to Mach-e 2025 Premium AWD Extended. The connection is fine. It used to work OK on Mach-e 2023.
Ford Mustang Mach-E vLinker MC+ OBD Screenshot3
Ford Mustang Mach-E vLinker MC+ OBD Screenshot1
Ford Mustang Mach-E vLinker MC+ OBD Screenshot2
I believe they changed the modules. There is a thread somewhere.
Because the 2025s use an encrypted CAN bus, so you won't be able to access those parameters anymore. Car Scanner no longer works on 2025s.
JimmyMachE
Montana
Mach E
Did you try another connection profile Mustang Mach-E 2023-? In "My Cars" you should probably create a completely separate setup with profile Mach-E 2023-
Tronjo
Nick
Canada
Mach-E Premium 2025
Thank you, Mach-Lee. Do you know an application that will work?
Tronjo
Nick
Canada
Mach-E Premium 2025
I did :(
tbrumleve
Tom
Oregon, USA
It’s encrypted. That means you’re never going to be able to read it. That means only Ford devices / software can decrypt. They’re never going to hand keys to a secure canbus.
